GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Man... I looked at this the other day & came came up with nothing... looked at it today & said I must be missing something... I was!!! When was the last time someone but the serial number before model number??? Usually other way around "MODEL then Serial #"... OK, back to the point....<br /><br />901<br /><br />My reference tool states that Chrysler Model 901-02 manufacturered in 1969... Hopes this helps...<br /><br />
To CORM & FONE-MAN, many thanks for the info. I needed parts and the dealer wasn't any help. Yes Corm,I copied the numbers just like they were on the plate. Again thank you both. Hal Virgo.
Hi Hal,<br />Did you take the 4 bolts out about 10" up from the propshaft to seperate the LU. If so the screw that disconnects the shift rod is towards the front of the motor. You should be able to see the waterpump body too. I don't know what the rubber pieces are.
