fishthebay
- Joined
- Aug 17, 2001
- 180
I have an 1987 Force (85HP) I went to change the lower unit oil today and stripped the drain plug. Its a 4mm allen wrench fitting. A very very small plug. Anyway, I can't get the plug out, so I trailered the boat up to the shop.<br /><br />The mechanic said to just leave it and don't worry about it. Now I did do a successful lower unit oil change in May, but wanted to do it again for fishing season here in Virginia Beach, since I will be running my boat a lot.<br /><br />The mechanic also told me that if I pulled the vent and fill plug and noticed a good clean gear oil to just again not worry about it. He recommended topping the oil off and checking it again the next day after it had time to settle.<br /><br />I did this and the oil is very clean. Obviously, I can't check to see if there is any metal shaving in the gearcase, because I stripped the plug.<br /><br />He said if I went to a machnine shop that they could probably tap it and put in another plug, but DIDN'T recommend doing this now.<br /><br />He said don't open up a can of worms. If its OK don't mess with it. He also said I could thorouly clean the area around the drain plug and put a little silicone there to assure myself no water leaks in. Now everytime I have changed this in the past I have noticed not any shaving or milky oil. Its always been great.<br /><br />Finally, he told me that I should never even have to change the oil. He used the automobile scenario, before there was no jiffy lube did you ever change your differential fluid?<br /><br />SUGGESTIONS SUGGESTIONS would be appreciated. Should I not worry and leave it?, Rockfish season opens in a few weeks and I would hate to be stuck on shore.<br /><br />I know force isn't a great motor from reading these posts, but I never have had a problem except for this. I figure if I can get a few more years out of it thats fine for me. What do I do???
