force head gasket
bobmoore
1990 force 120 L=drive .went to start the boat ,engine cranked slow ,but started ,ran good at idle it would die ,then crank very slow .i pulled the spark plug out of the bottom hole , then turned the engine over ,water came out .i took the head off ,gasket looked ok ,but there were some spots near the bottom hole .or could i have cracked the block,,help and thanks
ODDD1
Re: force head gasket
BOB, you gotta look at the exhaust gaskets between exhaust manifold and block. they are a common problem...when they fail the bottom cylinder usually gets wet...have fun they are a royal pain in the arse....
bobmoore
i was going to pull that of to ,head gasket looked ok, it,s not that bad i have the L-drive i can get to it pretty good,thanks
bobmoore
the exhaust manifold gasket was bad but it had a broken exhaust def.in it .thanks
ODDD1
bob, you want a used manifold? post yer e mail addy.
bobmoore
yea .but it,s for a L-drive ,a local aluminum shop here might try to weld it ,the weld on the center deflector broke loose.the local boat shop here said it can be welded.what do you think,and how much for yours ,,and thanks
ODDD1
bob , you can see by the pieces yopu got is was a crappy design.....i have seen guys toss the deflector an put em back together, an welding is an option too.....heck you cant do any worse than force did.....
bobmoore
A LOCAL MACHINE SHOP WELDED A ALL NEW ONE IN IT .AND I NOTICE THE BRAND NEW ONES DON,T EVEN COME WITH A DEFLECTOR.BUT I HAVE A NOTHER PROBLEM ,ONE OF THE CLYINDER NO.2 ON THE TOP PART HAS A GOOD MARK IN IT ,ALL OTHERS LOOK GOOD ,I CLEANED IT UP SANDED A LITTLE AND HONED IT LITTLE GOT SOME OF IT OUT THEN I USED A LITTLE J-B WELD ON IT AND SANDED SMOOTH. THINK THAT WILL HOLD UP ,OR IS THERE SOMETHING BETTER.WITH OUT TAKING IT ALL APART.THE COMP. IN THAT CYLINDER BEFORE I TOOK IT APART WAS 125.WHAT DO YOU THINK..THANKS
bobmoore
well i,ll be putting it back together friday nite ,that is if all the gaskets come in,i,ll let ya all know how it runs.got the book on the motor,the carbs were really out of ajustment the adjustment betwwen the two . and i,m sure the timing is off ,is the way you pull out all plugs ,turn over engine at full throttle the best way? thanks
bobmoore
just wanted to say thanks ,i was out in the boat today ,and it ran better then it ever has,the timing was off, the adjustment for the two carbs were off now it run about 5200 to 5300 rpm at about 38mph.i really don,t have any problems to ask at this time .i,m going to put in new plugs tomorrow ,the ones that are in it now are about a year old , think i should stay with the fac. one ,whats a good plug , i have champ. in it now ,...thanks
bobmoore
what would a 17inch prop do to my boat
I have a 97 force 120 well maintained, with only 180 hours on it and I am now in the process of my THIRD head gasket! When I got my boat in 97 I thought I got a good deal my only regret is the fact that I didn't upgrade to a better motor. CHEAP THINGS ARE NOT GOOD, GOOD THINGS ARE NOT CHEAP! And by the way last fall when I blew the last head gasket I did get the head shaved, other then the first year this motor has been trouble! I hear you calling me Yamaha 150!
sony2001
Bob you had a post on props for your Force. For six weeks I've been shopping for used props and I've ended up three that are different than my 19". <br /> 1 a 17" cupped<br /> 2 a 21"<br /> 3 a 19" four bladed composite<br />So far I would say cupped is worth only 1" more.
evin300
Sony, have you tried any stainless yet?
sony2001
Stainless are not a good idea here because everyone hits bottom atleast once a year. I picked up those 3 props used and for the price of a new one.
sony2001
I wanted to ask tiffany's dream what kind of gas he uses, but he's not a regular.
