I have a 1997 Force 90 HP that I just purchased for a replacement of another one that I have that I thought was bad. I took it out for a test run. It had been setting for almost 2 years. There was 1/2 tank of fuel and as I was only going for a quick run I put the boat in the water and took off. I checked the water bypass and it was pumping OK. I went for approx 400' of no wake area and kept an eye on the water stream (still pumping). When I came to the end of the no wake 6 MPH area I opened it to WOT. I do not remember looking for the water stream at this point. I did not get 300' and the motor seized and stalled out. I immediately went to neutral and pulled the cover off of the engine. The head gasket was bubbling and the block was very warm to touch (I could hold my hand on it but it was warm). The hot horn went off and I thought it was a ign on buzzer so I turned the ignition off. I let it set for a couple of minutes (trying to figure out how I was going to get back in). I decided to try the engine to see if it would turn over. It turned over fine. I cranked it a few turns to pump in a little water and then i stopped. I waited a couple of minutes and repeated the sequence. I did this about 3 times and then the 4th time it fired up and I shut it down immediately (because it was steaming out of the exhaust and the stream hole every time I had cranked it and when it started). I waited a couple of minutes and fired it again and immediately shut it down. I repeated this sequence about 4 times and then I started it and let it run until water came out the hole and then shut it down. I let it set for a couple of minutes and then started it and proceeded back to the dock. It sounded the hot horn again and I shut it down. I waited a couple of minutes and started it again limped in at a slow speed (shutting it down every 50 feet or so and starting again). I ran it steady for the last 200' or so with no problem. It did sound like marbles in a tin can but I did not really pay attention to the sound (it was a loud engine - louder than my 1991). My question is what should I do to see if it is hurt or OK or whatever???
