Hi Everyone,<br /><br />I really need some knowledgable FORCE owners here.<br /><br />I just bought a 1986 Bayliner Capri with a 125 FORCE motor. (I am learning fast about the problems) <br /><br />I was told by MANY people to check the water pressure first before taking it out. I purchased a water pressure gauge and connected it to the water plug on top of the motor (silver plug right above Thermastat housing)<br /><br />Whith the motor at idle there is little or no water coming out of the hole EVEN with the thermostat removed. My father and some others on this site told me to replace the impeller. I just replaced that (MADE SURE I PUT IT IN CORRECTLY) and it still has little or no pressure at idle. At about mid throttle, I get MAYBE about 5PSI on the gauge. I checked the lower unit and it is clear from anything blocking the incoming holes and I checked the thermostat opening and it is clear. I blew air up the Impeller tube and it is clear. WHAT GIVES? I am starting to wonder if FORCE motors run at REALLY LOW pressure. Any help would be sooooo appreciated as I have spent about 10 hours on this problem now and am ready to be comitted.<br /><br />Thanks.<br /><br />Tony
