1995 Force 70 hp No forward gear
fisherfrk
I recently damaged the skag on my Force. The unit was removed and the repair was done very professionally. When I got it back it ran fine for about 5 hours. Then while pulling a tuber, I put it in forward and it did not go into gear. I tried a second time, nothing, so I tried reverse, that worked, I tried forward once again, nothing and finally I tried reverse again and nothing. I had the linkage adjusted and in the yard it was shifting fine, though we did not run it with muffs. When I launched it, reverse was great, but no forward gear. At no time was there any sound of grinding.<br /><br />Now even manually, I can not set forward and at times, if shifting from reverse back to neutral, reverse sticks.<br /><br />I have drained the unit and the lube is perfect, no indication of grinding. Any help you can provide would be great!<br /><br />I am sorry, I first listed this in the I/O section, hope this correction is not a problem.
fisherfrk
Re: 1995 Force 70 hp No forward gear
the skag was damaged while loading on the trailer, no damage to the prop or any other portion of the motor
fisherfrk
Bear, thanks for those links, I assume I'll be able to find most of the other diagrams for the engine and unit as well? This may save me a lot of money.
fisherfrk
Thanks Bear, the mechanic who looked at it, told me that when the skeg was welded and reassembled, a cotter pin was left out and after a few hours the linkage separated leaving me without forward. Seems to be back in order now. To tear it down and put it back together he charged $60, I think that was fair. <br /><br />Thanks again for your help, I love the site. :cool:
