Re: 1988/19' Bayliner/125 Force/how fast and how many RPM's wideopen?
you might be running on only 3 cyls. I have a 3 cyl 85 hp , and when it was running on 2 cyl's ,it would only go 20 mph ( no tack ) with 38 mph normal . it DIDN'T seem like it was skipping , but was really running on only 2 cyl's. if you have had cd trouble , the cd may not have been hooked up right,or the 1/2 of the cd for that cyl is bad and is not firing . check the plugs . if this is a new boat to you it may be badly over proped ( too much pitch ) , but i doubt this is the problem . check the plugs , take a compression reading on all cyl's and if you find a non-firing cyl , go from there . Rollie
