computerdude00
- Joined
- Aug 6, 2002
- 10
Doing some work on an engine that came with a new boat. It's a 1987 Force 35, and upon removing the propeller found that fishing line had gotten wrapped around the prop shaft. The line was literally fused together into a washer from heat and pressure. There was nothing else between the lower end and prop. It appears that a fairly deep goove has been cut by the line into the brass hub of the prop. The lower end looks flat and smooth. My question is two fold: first, is the prop history, or is it repairable? And second, what if anything should be on the shaft between the prop and lower end? (washer or bearing?) The following link is the best attempt I could make at a photo- the end of my index finger has about the same shape as the cut into the prop hub. Thanks for entertaining my newbie-ness!- Todd<br /><br /> <br />Prop Photo
