120 force
rms
I have a 95 model force 120 checked compression it was 130 on #1 and 145 to 150 on others is that normal
sony2001
Re: 120 force
I find it at the limit of acceptability. If the rings have carboned up spray some decarb thru the spark plug hole around the piston and let it sit overnight. Then give it a run. If after a couple of treatments it's still low, start to test for a leak in the head gasket. Does the #1 plug look like the others? :cool:
