SS MAYFLOAT
- Joined
- May 17, 2001
- 6,372
I'm in the process of redoing my transom (see boat restoration thread). Last year I installed a thruhull fitting using the 5200 as recommended by the expert help on this site. This stuff was a bear to get loose to remove my fitting for the repair.<br /><br />With it being so tough, but flexible somewhat, would this be good to bond my marine plywood to the hull in the transom? I would cover the wood and end grain to prevent water intrusion. Of course after the cure period I would glass in the new wood bonding it to the hull. I'm just thinking that the 5200 could give a better stronger bond than using epoxy or polyester resin. <br /><br />Open for suggestions.....thanks.........SS
