Re: Force 50 HP Won't start
First, undo the brown wire from the terminal strip on the side of the engine, and tape it off (so it dont touch anything).<br /> <br />Next,Remove the fuel line.<br /><br />Next, use fresh gas/oil mixed in a spray bottle, and shoot some fuel into the carb body.<br /><br />Try to start.<br /><br />If it fires-off, you have ; stale or contaminated fuel, a shorted kill switch, or other fuel delivery problem.<br /><br />If it does not fire off, use a meter,and check for proper voltages and coil resistances as per manual instructions.<br />Then take the flywheel off if it turns-out to be a trigger failure.<br /><br />More than likely, the plugs are contributory tro the problem, if they are ANYTHING other than Champion L82-C.<br /><br />And huffdaddy is dead-on here.. ("fuel/Spark/compression=boom")<br />So check this engine's compression. Seeins how someone stuck oddball plugs in this engine, they may have had time to do thier damage to the jugs and pistons, making all other problems moot.<br />Good luck
