OwenCollar
Thread starter- Joined
- Jan 11, 2003
- 3
Hi, wondering if anybody could help with the problem I am experiencing? I have a 1990 Force 125hp outboard. The problem is with the power trim and tilt, It consists of two cylinders and a seperate shock absorber. The Trim works perfectly and is 100% reliable, the problem is with the Tilt sometimes it works OK, sometimes it works but very slowly. and sometimes it gets to the limit of the trim and then the tilt stops completely! The motor works OK and the RPM is OK. Their are no leaks and the leak-down tests work OK.<br /><br />I have studied the Clymer Manual which doesn't seem to highlight this problem.<br /><br />Any help would be much appreciated.<br /><br />regards Owen Collar.
