ClaytonSikes2003
Thread starter- Joined
- Feb 24, 2003
- 14
Hello Board!!<br /><br />Tonight I was attempting to replace the impellor and housing on my Force 85 outboard when two of the bolts holding the waterpump housing broke off. Fortunately there is about 1/2" of the bolt protruding, so I don't see too much difficulty in removing the bolts (I will be taking it to a machine shop to have the broken bolts removed anyway). This breakage forced me to remove the gearcase cover and while attepting to do so (I tried to gently use a flat tip screwdriver) the mating surfaces got a little scratched. It doesn't appear to be bad, but I am really not sure as to how precise the fit needs to be. There are no gaskets here, only a couple of o-rings. Can I just use some silicone sealant to ensure a good seal, or did I really screw up a precision fit?<br /><br />Thank you for your help.
