haus and phefer
Thread starter- Joined
- Jun 5, 2003
- 5
I need some serious help with my boat. I just bought it a few weeks ago. The numbers are model 456ha and the serial is 3378, it is a chrysler. Any help identifying the motor would be appreciated. The boat starts fine, and even runs pretty good on the trailer hooked up to a hose but once you set it in the water it still starts but it wont idle very good and it seems if i choke it alot it will barely keep it going. I can sometimes keep it going in neutral but if i put it in gear it dies within 50 ft. it was miss firing one of the cylinders so i changed the plugs, that got it firing again right. Other than that i have taken the carb off, found a very very small amount of something in the horizontal jet, but for the most part everything looks clean as a whistle. I also wanted to know if the waterhose outlet should be closed up when you are in the lake. Somebody told me that it could make a difference. I am lost, any input will be appreciated thank you.
