oh no the 50 force no full throtle
riverbass
i have changed the coils stator cdi unit cleaned the carb and still no full speed how do i adjust the timing its a 89
12Footer
Re: oh no the 50 force no full throtle
Avoid adjustment of the timing on this motor. They rarely if ever jump time, and as long as nobody messes with it, it will be set.<br />Do you get full RPM? Lots of revs, but no go? If so, remove the prop,and rehub it.<br /><br />Are you sure it is an ignition problem? This motor simply will not idle if you are down one cylinder for any reason. So if it runs in idle, move to the fuel delivery.<br />Check the compression,from tank-to-carb.<br /><br />The fuel pump on this motor is cheap and easy to rebuild.<br /><br />Check for air leak in the fuel line.<br />Make sure tank vent is open while operating.<br />check the screen on the bottom of the tank pickup tube (or try another tank).<br /><br />And make sure the throttle butterfly in the carb opens fully at full throttle.
riverbass
i replaced the stator last year before i did the boat ran realy good until it needed a ststor ever since i changed it i havent had full power when i removed the flywheel i didnt mark it should i have marked its location to put back in the same spot
12Footer
The flywheel is keyed, so you should be ok. Check the timing in idle. As long as the linkage has not been changed, it will track-up just fine.<br />If it has, you will need a pilot at the helm and a trip to the river.<br /><br />Does it idle?
riverbass
yes it idles very well starts no problem im buying a tach this weekend to check my rpms then go from there any input is welcome thank you very much
pwilson
Have you checked the TRIGGER? It could have a loose or bad wire.The trigger is the round part located below the stator and flywheel.The factory original trigger will be made of metal.Wiggle the wires around a little @ W.O.T. and see if it picks up any.You can also check the voltage to and from it, to be sure. :cool: P.S. aftermarket trigger made of plastic.If you have a bad trigger wire it will loose a cyl. under a load.
riverbass
i have finally found the problem the butterfly on the throttle was to far ajusted so it was coming back around it wasnt at 90degress so i set the throttle at wot and adjusted the clip on the side of the throttle lever to set at 90 degress wot and its flying on the water thank you every one who helped me i hope i can return the favor
12Footer
Glad to hear you are back in the saddle
