fishmongrel
- Joined
- Jun 27, 2003
- 2
I bought an '89 Maxum w/Force 50hp a couple months ago, and when I changed the gearcase oil about 2-3 ounces of water drained out before the old oil did. I refilled the gearcase and tightened the screws down, then ran it in tub until it reached temp. I idled w/prop engaged for about 10 min. Then ran it with prop disengaged at high idle for another 1/2 hour. Altogether it was run in tub for a good hour to an hour and a half at mostly high idle. I checked the oil afterward and no trace of any water. What usually causes water to appear in the gearcase oil? A loose screw? I did tighten the screws much harder than they were previously (used a wrench on a screwdriver). Think I should take it for a short spin and recheck it, or should I head straight for the marina? Much obliged for your input guys.
