ski_fl_water
Thread starter- Joined
- Jul 2, 2003
- 7
I bought a boat with a force 150 on back. It started and idled fine at first. It reved up and then started backfiring and carring on at all rpm. The first prob I ran into was no spark cyl 1. New power pack cured that prob. Still acted up at all rpm. Timing was at 28 degrees and all other spark plugs fired. Rebuilt carbs and checked fuel pump. Ran through several wiring diagrams and found different ways to wire stator, power packs, trigger, and coils. The diagram on the motor is what I am using. Is it possible that the trigger would cause the firing order to change causing the rough running and backfire? Idles ok sometimes and won't stay running others.
