35 HP Chrysler overheats
slgny
Has overheated several times, last time dealer<br />put in a new impeller. After 4-5 hours it overheated agin. I took it apart and the impeller was like new. I discovered that it does not<br />have a thermostat. Could this cause it to run<br />poorly and overheat?<br /><br />Thanks Gary
scotiany
Re: 35 HP Chrysler overheats
In a word, absolutely. The Seloc manual devotes about 3 paragraphs to what happens if you run without a thermostat-none of them are good. You also have a water pressure relief valve in the water jacket that could be stuck. Hopefully, that won't be your problem. I think yours takes a 145 thermostat.
