Force 120 Steering
Macario
I am new to boating and I just purchased a 95' Starcraft 1700 with a 95' Force 120. When I try to turn the steering wheel the motor is stuck in one place, all the way to the right. Is there a lever or button that releases the steering? Can't figure it out. Thanks for the help!
roscoe
Re: Force 120 Steering
No, there is no lock on the steering that I've ever heard of.<br /><br />I am assuming you did not take this boat for a test drive.<br /><br />First you need to determine where the problem is.<br />You need to disconnect the steering cable where it attaches to the steering tube on the motor.<br /><br />Then, if the motor still won't turn, the pivot tube in the motor has froze up. Penetrating oil and grease are the answer.<br /><br />If you can turn the motor by hand, then the problem could be in the steering tube(corrosion, clean and grease), the steering cable(replace it), or the steering wheel assembly.<br /><br />Don't be afraid to ask for more help.<br />You will have a nice rig once you get the bugs worked out of it.
Macario
Thanks for the advice. I will try everything you suggested and will let you know the outcome. If I come across any problems I will let you know. Thanks again!
