85 HP Chry Force Miss
Cable2112
I have a 1984 85 hp Chry Forces that has been setting for about 5 years. It starts right up but has a miss periodicaly at idle. It will also miss as u increase throttle. The carbs have been cleaned with cleaner and nothing seems to change. Any help will be greatly appreciated.<br />Thanks, Cable
scotiany
Re: 85 HP Chry Force Miss
You might want to rebuild the fuel pump(cheap and easy to do ). Also, I would completely disassemble and soak the carbs and rebuild. Kits are available here at iboats and NAPA. I would also change all fuel hoses and the bulb.
