1988 125 force rough idle
brooksbayliner
I fianlly got the dang thing back together agian new water pump form overheating new thermostat put the foot back together an now the dang engine while in idle will run for a short few minutes an then cut off is it because it sat for a few weeks or what are there any trick or things to look for when trying to make the engine run smooth for the summer or till i can get another engine someone please help
12Footer
Re: 1988 125 force rough idle
I'm concerned over this sequence of symptoms.<br />Your motor ran fine before changing the impellor out, and now it runs poorly, and the fuel is only 2 weeks old....<br /><br />My approach to this problem would be to inspect the fuel tank and carb bowls for condesate.<br />No water? Compression test and plug inspection.<br />My reasoning here --- more water pressure in the cooling circuit of a previously-overheated motor, could be allowing water to enter the combustion chamber.<br />If this motor overheated, the head gaskets, exaust port plate gaskets, or both may have warped,causing them to loose seal.<br />I know this is somewhat "Spock-logic", but it makes sense to me, to check those items first.<br />Plugs should have some signs of operation, and not "brand new looking", even after only 1 hour of run-time. If any one of them is spotlessly clean, or is clean except for minor rust, means water injestion. Ungood. A side-note:<br />Water in the fuel system can also steam-clean your plugs, but they would be all clean from each associated carberator (carbs serving more then one cylinder), giving those plugs a dose of water at the same time. So look for one or two conspicously-clean plugs.
brooksbayliner
come to find out the head gasket was warped but head was not i am putting new head gasket on the engine tommorrow an a tempature gauge an then testing it in the water on saturday thanks for the info
