diggitydave052
Thread starter- Joined
- Jun 17, 2004
- 9
Hi All<br /> I have read all about the big mean pivot screw of course that is after I remover it. I have a 1981 Chrysler 75 hp with a type C lower unit as referred to by Seloc manuals. I feel I might be ok, firts question is will oil come out the pivot screw aperture ??? Also when I removed the pivot screw the boat was in nutral and the motor was in full tilt. I heard nothing fall and was suggessfuly with the oil change. I am dealing with other problems with my motor so I am not able to start it at this time to check shifting status. Is there anything I can do at this time to test linkage. The shifter feels just fine and still only turns over in neutral position. Is there any chance that the pivot screw only caught a few threads on the shift coupler, I would not want it to break off down the road or should I say on the water. Also I should say a impeller job is about due. Let me know boys, I know you will.<br /> Thanks for your time<br /> dave <br /><br />PS: Last year I changed oil through same pivot screw hole and had no problems all season
