i need some help finding a fuel leak can't tell where it is coming from i took the panels off of<br />motor right above lower unit & can see fuel leaking from bottom of engine the fuel comes out right above the lower unit but there is no fuel <br />present in the motor casing just wonder if this a common problem and if somebody w/ a little mechanical knowledge can fix it also the prop can be wiggled about a quarter of an inch is this normal ? can i buy a shim or is the lower unit worn any help would be greatly appreciated
