Force 125 thermostat problem
Andy67
Hello<br /><br />I replaceed my thermostat and I don't know if I put it in right, is it possible to put it in the wrong way. <br /><br />The water that comes out is warm after just 1 minute.<br /><br />Another question, how mucht gas shall whis motor use for each distans (1852meter)I think mine takes 1,5- 2 liter/' is that normal?<br /><br />Best Regards from Sweden
roscoe
Re: Force 125 thermostat problem
Thermostat in backwards?? I don't know.<br /><br />Fuel consumption appears to be a little high, but not unheard of, particularly if you have a heavy boat and are operating at full throttle. Better economy to run at 3/4 throttle.
Scaaty
I don't think it would fit backwards. The spring part would sit in the cover. Easy to just pull and check, and dab a little blue RTV silicone on and slap back together. But if you had it backwards, it would not warm up I would think.
Andy67
Now I have checked the thermostat and it could only be mounted one way.<br /><br />But still I think the fuel consumption is to high.<br /><br />I run the boat at 3500 rpm ( max is 5000)
Scaaty
I run mine at 3500 too (20 footer) and use about a quesstimate 5 gallons an hour
