I need some help from you force gurus. My outboard ran good then a magnet fell apart which bent the throttle control link.I took it out and put it on the trailer and then home.I then installed a new flywheel and throttle control link and when I tried to start the motor it would crank and every once in a while back fire.The motor ran good untill I stopped it in the water but after installing the new parts it wouldnt.If I installed the flywheel and I did install it correctly I shouldnt need to re time the motor I checked the fuses thier ok I have always worked on cars but to be honest have no idea where the timing adjustment is on this motor even the manual doesent show much what tests should I do thanks guys
