Hello,<br /><br />I've got a 1987 Force 50hp outboard that leaks gas out of a jet on top of the carburator when idling. The motor has been sitting in the sun and only has about 15 hours on it. I'm guessing that the needle seat isn't sealing and gas is filling the carb and going out the jet. Is that correct? It looks like I should take a paper clip with a short bend and pull the seat out. Is that the way to do it? Is the coil spring necessary in the float bowl? This one is missing. Are parts hard to get for this motor. It usually takes 2 to 2 1/2 weeks to get them from Mercury Marine in Fon Du Lac. Is this a good motor or should I peddle it? Thanks. Bob
