A puddle of black oil collects under the cowling aft of this motor. I suspect gasket between upper and lower motor (exhaust manifold?) is leaking. <br /><br />I thought I'll just crank those 6 little bolts down a bit to see if they're loose. (Separating upper and lower engine is a lot of work!) But they are an odd star-shaped head.. <br /><br />Can someone enlighten me what the proper term for those bolts are and whether this is a potential source of the problem? Where do I get a star-shaped socket for my torque wrench? I've heard others with pooling oil in the cowling... where does it come from usually?<br /><br />Thanks! Rodbolt, I'll bet you know the answer!<br /><br />Bioman
