TrophyFish'n
Thread starter- Joined
- May 31, 2005
- 10
I have twin 93 Force 120's and they run really great, very well maintained, however I'm noticing a problem. It seems to occasionally when running at above 10mph and around planing speed to even higher speeds like 30-35mph it will seem to slip while in gear as in the rpm's go up and the engine sound gets faster but the speed stays the same. I've noticed that this will happen a little more when the boat is near plane speed probably due to the higher torque required there. It's not the props as I have switched them out to brand new ones. I usually have to slow down put it in neutral and then shift back into forward and try it again. Sometimes it will run for 20 miles without a problem offshore but then it will start to happen so it's hard to predict. It seems to happen more with heavier load in the boat but it will still happen with a lighter load too. Since I've replaced the props (it's a twin 120, bayliner trophy 23 walk around cabin and both engines do the same thing from time to time), I believe it's something in the lower unit like the clutch mechanism being too weak or something. I'm seriously thinking about tearing down the lower unit and worse comes to worse get a rebuilt unit for about $1000 to $1300. Will probably have to do both of them but will try one unit at a time. What does everyone else think? Anyone else come accross the same type of problem? I've replaced the lower unit gear lube many times and have never seen any metal debris. The oil is always in pretty good condition however I've only owned the boat about a year and there's no telling what has happened in the past. Thanks<br />TrophyFish'n
