run gas out of carbs after every run?
peacekeeper6
who does this and who doesnt? should u do it? or should you not? whats the advantage disadvantage?
speeddemon1452
Re: run gas out of carbs after every run?
I shut off fuel and let it run tell it runs out.don't know if its good or not but its just how i do it.
scotiany
My original Chrysler owners manual doesn't say anything about doing that.
eurolarva
It is not advised to run the gas out of the carbs. When gas leans out cylinders are not getting lubricated because of lack of oil in the gas. Winterizing with fogging oil provides the lubrication the motor needs when running the fuel out of the lines
peacekeeper6
o, so as the gas gets low not enough gets to the cyclinders. how long does it take approx to build up enough gunk to clog carbs?
jasonbailey
If you run the gas all the way out of the carbs you starve your main bearings for lube. Not a good thing over the long haul. What I do at the end of the season is put Stabil in the fuel and run that through the carbs. Shut the motor down and I'm done. I also use the fogging oil. This is the 4th season I've had it and it starts up and runs perfectly in the spring. It usually starts on the second crank. In addition to running the Stabil through it, I suppose you can drain the fuel bowls. The other risk of draining the carbs is that all the gaskets and such tend to dry out and split. <br /><br />Also the last tank of the season gets pumped out and I burn it off in my car. I usually have about 3 or 4 gallons left over. Fresh gas goes in on the first start of the season. I make sure the last trip of the season burns most of my gas. I mix that 3 or 4 gallons to 12 gallons of straigt gas and I've yet to foul anything in my car. The car that I burn it in is my beater so not to worried about it.
Docdoc
I vote for using Sta-bil. It doesn't affect the motor lubrication and will not leave varnish in the carbs.
monkeyboi
how long will sta-bil last? uncle gave me an OLD bottle-should i use when the cold comes?
Docdoc
Stabil by itself should be good forever if kep well sealed. It is supposed to keep gas good for at least 6 months. Use it when the cold comes. I know guys that use it all the time to help keep the carbs clean.
