Second time on this one. Took the boards advice and rebuilt the fuel pump. No luck. Boat will still not get faster than seemingly about 1/4 speed when WOT and will not get on plane with just me in it. Compression is top to bottom 120/118/115. Ran a can of seafoam thru it as well, when I was trying to load up the engine with the seafoam I could tell a change on the top and mid carbs but there was no change in running when I sprayed in the bottom carb? Problem with the bottom cylinder????? I checked the fuel lines on the engine itself and they seem to be ok, as in the previous post I have already changed the main fuel line. Also, the plugs were not really dirty as they should have been after the seafoam (first time I did the decarb this year) The model number of the motor is 856X6L...Is there anything else I can try before I send it to a shop. I have another set of carbs that were rebuilt last year (got them from a friend and dont know how dirty the inside might be) and another set of coils.
