screamin demon
- Joined
- Sep 5, 2005
- 6
The trib tab was busted off the lower unit. During the short time it was off the boat the steering was very hard (turning right) while under power and on plane. I replaced the trim tab and the problem never went away. <br /><br />The steering is OK while the motor is off and in neutral (at idle and higher RPM). As soon as i put it in gear it gets a little tougher and as I accelerate it is stiff as a board. I have to use everything I got to turn it. Once on plane it is only hard steering to the right. <br /><br />Something to mention. While the enigine is off the steering is fine however when i turn all the way right or left the fly wheel turns in the opposite direction (it appears to be even in each direction). <br />Not through out the entire turn but about 2/3 into it. <br /><br />Thanks for any insight.
