92 Force 90HP water inLowerUnit
pneitzer
I'm looking at a boat with a 1992 Force 90HP. The engine runs fine but the lower unit is slowly taking In water. Is this a common problem? POSSIBLE FIXES?
steelespike
Re: 92 Force 90HP water inLowerUnit
Speaking genericly <br />this occurs on most motors over time.Usually replacing the prop shaft,drive shaft and shift shaft seals will solve the problem.
roscoe
You might get luckey and fix it by replacing the gasket/washers on the fill and drain screws.<br /><br />Cost, $1 for the washers, plus $5 for a couple quarts of lube.
12Footer
L/U's should be checked after each outing (if possible), for just this reason.<br />It's not only common, but inevitable for a L/U to develope a leak over time. And runtime hours are not the only thing that causes leaks.<br />Not so much of a problem down here in Florida as up north, just sitting on a trailer can destroy the L/U as the water inside freezes and expands.<br />Running a motor with comtaminated lube usually ends-up in a grenaded L/U.<br />But to answer your question, it is common and routine.<br />However, with the motor in neutral, rotate the prop by hand while watching the porop shaft, or prop's center, for any wobble or out-of-true -- This could mean a bent prop shaft, and is a VERY expensive fix.<br />If the prop has any chips or pieces missing from any of it's blades, it may be running out of ballance, causing the seal to wear prematurely.<br /><br />Not that having new seals installed is cheap, but it will be by comparison.<br />If you are handy, get the manual, tools,L/U seal kit and a new impeller, and go for it.<br />Otherwise, expect about a 250dollar repair bill for the job. Add an additional 100-200, if the drive or prop shaft is bent.<br />Ah yes....Just one of the many "ca-chings" to boat ownership. :)
