Motor mounts and tach 120 force
Kajun37
there is a mount on the backside of the motor above exhaust port.....its looks like it is broken or the rubber cushion has came off (picture #1) and then then other mount at the front bottom of leg is bad also(pic #2&3)...i can move the leg back and forth....can i buy these online somewhere or do i have to find a old motor?...also can i get away with just replacing the top back one?<br />
<br />
<br />
<br /><br /><br />second question....i bought a generic tachometer from ebay...the guy said its a universal tach...but the backside different than my teleflex tach(which isnt working)....will this one still work?<br /><br />
<br />
roscoe
Re: Motor mounts and tach 120 force
Tach doesn't look good.<br />You need a tach for a motor with 20 pole charging system.<br />They are usually marked as such.<br />Not many that will work.<br />You need Teleflex 20 pole tach, part number 53743p<br /><br />Lower mount is available from Mercury, part number 803714T , LOWER SHOCK MOUNT. Number 10 in this picture:<br /><br />
<br /><br /><br />Not sure which part is broken in the first picture. Maybe you can find it here:<br /><br />
<br /><br />Your friendly neghborhood Mercury dealer is the place to go.
Kajun37
thanks roscoe...the top mount is the L bracket that has 4 bolts on it....i guess it used to have some sort of rubber mount attached to it..now that its gone it allows the motor leg to rock back and forth.<br /><br />if i can find one of the top ones i'd rather just replace that one since its easy to get too...that lower mount looks like i would have to dissemble the whole lower half of motor to change it out:(..the lower one still has the rubber on it, its just separated and seems like if the top mount was there it would still work.
roscoe
Part #10 here?<br /><br />part number F335654-2 STOP-DEFLECTION Only $10 !!<br /><br />
Kajun37
thats the one..thanks
Richym01
Hi Roscoe<br /><br />Cam you tell me how often you should replace the mounts? I have no visible sign of damage but the I can move the engine back and forward slightly?
roscoe
Sorry Richy, I have no idea.
Kajun37
richy..your engine(powerhead) is moving or the leg?
Richym01
Hi Kajun37<br /><br />If I move the leg bacl and forward the power head is moving aswell. It is not moving alot but it is still moving. <br />Thanks for your help
