roscoe
- Joined
- Oct 30, 2002
- 21,970
Re: Is my motor shot? UPDATE!!!!! TEST RUN
I wouls do the temp warning buzzer, and a water pressure gauge. The pressure gauge will let you know about an impeller failure BEFORE the engine overheats, if you look at it once in a while.<br /><br />It simply screws into the little pipe plug on the top of the engine, just above the thermostat housing. Run the plastic tube to the dash , install the gauge and attach the tube.<br /><br />They sell the water pressure gauge kits in the iboats mall.<br /><br /> http://www.iboats.com/mall/index.cg...ure+gauge&submit.x=0&submit.y=0&submit=Search
