firing order 2
Kirkman24
I have a Crysler Skier 700, Model # 709H9A Serial # 4366. I was wondering if anyone knew the firing order?? I changed plugs and wires but forgot to write down the firing order. iIt is a 3 cylinder with the rotor cap? Thank You for any help in this matter.<br /><br /><br /> Kirkman24
eurolarva
Re: firing order 2
The firing order is 1-2-3 on a 70 HP. Four cylinders are 1-3-2-4
roscoe
Re: firing order 2
I think he needs to know which plug wire from the distributor goes to which cylinder.
Kirkman24
Re: firing order 2
Thank you for answering.....Yes i do need to know what wire from the distributor goes to each cylinder. It is a 3-cylinder. Thanks again for any help..<br /><br /><br />Kirkman24
eurolarva
Re: firing order 2
I cant find any procedure in my clymer manual to give you the correct answer. My best guess would be to find TDC on the top cylinder and find what wire the rotor is pointing to and that would be Wire 1 going to cylinder 1, Clockwise on the distributer should be 1,2,3 where the cylinders from top to bottom are 1,2,3
