FORCE 85
teardown21
YES IAM NEW TO BOATING BUT REAL GOOD WITH MECHANICS BUT ON CARS NEED SOME HELP WITH MY FORCE 85 .<br />I GOT THE BOAT FREE BUT THE MOTOR LOOKS LIKE A FRESH REBUILD ON IT RUNS GOOD STARTS GOOD BUT ACCELERATION SLOW I CAN ONLY GET 25 MPH OUT OF IT. ITS MONTED TO A 19 FT. RENKEN. PLEASE HELP?
SpinnerBait_Nut
Re: FORCE 85
Welcome to iboats mushga, let's get this to the Force forum to get you started.
roscoe
Re: FORCE 85
If its a fresh rebuild, you should be running double oil for breakin.<br />Its gonna smoke awful, but you need 5 ounces of TCW-3 oil, per gallon of gas, for the first 10 hours after rebuild.<br /><br />Gotta ask some questions to get us headed in the right direction.<br /><br />Does the boat have a tach?<br />If so, what are the rpm's when you reach max speed?<br /><br />Have you checked for spark and compression on all 3 cylinders?<br /><br />What is the condition of the prop, all banged up or pretty straight and nice?<br /><br />Is the boat crrying any extra weight, is the hull or floatation foam waterlogged?
teardown21
Re: FORCE 85
hi roscoe thanx for your time and effort,<br /> this engine sat for a long time bt after cleaning arbs the motor started right did no other trouble shooting was done i got the boat running pretty good today but used alot of gas in one huor used ten gallons of gas is that bad, how doi tune the carbs i dont think they are opening all the way up, today when i was out onit she ran about 30 to 31 mph is that about right
roscoe
Re: FORCE 85
30mph sounds pretty good for that motor and that size boat.<br /><br />You said the accelleration was slow. How long does it take to get up on plane when you hit the throttle? 10 seconds? 20 ? 30 ?<br /><br />Gas consumption seems high. Would expect 7-8 gallons per hour if running at wide open throttle, about 5 per hour at 3500rpm.<br /><br />If you're gonna do any work on it, you really should get a Clymer Force Repair manual.<br /><br />I would:<br />Check compression.<br />Put in new plugs.<br />Change water pump impeller.<br />Change lower unit lube.<br />Replace fuel pump diaphram and gaskets. Get them from NAPA, or a Merc dealer. Parts are about $10<br /><br />Fuel pump leaking into the powerhead may be what is causing the high fuel consumption. Pretty common. Eventually it will leak bad enough that the engine will flood, and not start.<br /><br />Setting carb idle mixture is pretty easy, just don't run it lean.<br />If your motor is 1984-1988, the starting point is 1.25 turns out from seated. If it dies when you accellerate, it is too lean. You want it to stutter/hesitate a little, then take off.<br /><br />Don't mess with the throttle/timing advance tower until you have a manual in hand, and have read it.<br /><br />If the boat doesn't have a tach, consider getting one. You need a "20 pole" tach. Use the tach and measure WOT rpm (wide open throttle). Use the rpm info to determine what pitch prop you need.<br /><br />Sounds like you got a boat that runs, for free. Who wouldn't want a boat that runs, for free? I mean, its a boat, and it runs, for free. Cool.<br /><br />The trick is to keep it running. :) <br /><br />Don't hesitate to ask for help.
