Took the boat out over the past weekend, started fine on Friday, got us to where we needed to go. Had it moored over night, went and fired it up Saturday morning around 10am, no problem. Went for a quick burn, then parked it. Later on in the day around 5pm, went to start it again and it wouldn't fire. It was cranking with no problem, but I could hear the crank / battery slowly losing power with every crank. Left it for the day. Tried again Sunday morning, it did fire, but then died (which is normal). But when I went back to fire it again right away, it wouldn't fire. It continued to crank, just not enough juice to fire it. We tried jumpstarting it with neutral batteries, just extras we had lying around. Eventually we got it jumpstarted off someone else's boat that had been running and was revving high while connected to mine.<br /><br />Once started, it runs perfect. No idling issues, max rpm is around 5500, I usually cruise at 4200-4500rpm.<br /><br />Once I got home, I brought the battery to an electric shop, they tested it and said it was fine, he actually asked me if I had charged it before bringing it down, and I hadn't. He also said the load test read good also, so that would eliminate the alternator?<br /><br />So my questions are, is there anything draining the battery that I don't know about? Since the engine is cranking, it's not the starter, is it?<br /><br />Am I just flooding it? Maybe I'm choking it too much?<br /><br />Could it be a fuel problem?<br /><br />What about the solenoid? <br /><br /><br />Thanks for all your help guys, this is an amazing board.<br /><br /><br />SSS
