1989 Force 125 Problems
Fishcapades
I have a problem with my dads 1989 force 125..<br />Last summer while i was comming back in to the marina the over heat alarm came on.<br />I coasted back in to our slip and left it for a few hours and went back and started it and everything was fine.<br /><br />Well the problem is back now.<br />We brought it home to fish the st clair river and i decided it would be good to let it run on the hose for a while today.<br />It ran fine for about 10 minutes and then the alarm came on.<br /><br />I shut it down and waited about 5 minutes and it the alarm was still on when i turned the key on.<br /><br />Dad told me to start it up and see if any water came out of the pisser.<br /><br />Nothing was coming out at all. there was water coming out from the prop though.<br /><br />Is my water pump shot? or is it the thurmostat?<br /><br />I have the Service manual and am sure i can handle this myself. <br />I dont believe the water pump has been change in about 5 to 7 years since the lover unit was replaced due to it meeting a piling on lake huron.<br /><br />If it is the water pump could the motor of sucked up peices of the impeller? How would one go about making sure the peices are out of the cooling system?<br />Could i take compressed air and try and blow it back to the water pump?<br /><br />Thanks for the help
jasonbailey
Re: 1989 Force 125 Problems
You are due for a new water pump anyway. I change mine every two seasons. Also do a compression check to make sure you have not blown a head gasket. A blown head gasket will cause an over heat alarm as well.
Fishcapades
How would I know if it has a blown head gasket? I dont really want to tear in to the motor unless I have to.
Scaaty
Originally posted by Fishcapades:<br /> How would I know if it has a blown head gasket? I dont really want to tear in to the motor unless I have to.
Change the impeller first, then try it. If still heats up, start another post, and we can work at it again
roscoe
Change the impeller.<br />Examine the water pump housing for pitting or scoring, replace if needed.<br /><br />Buy or borrow a compression tester ($30).<br />Test compression to determine if head gasket is bad.
roscoe
Iboats Marine Mall on this site may have the impeller.<br />Or mercruiserparts.com/Show_Pictures3.asp?dnbr=FOB4281&ivar=images/FORCE/FOB4281/33.png&inbr=1288&bnbr=130&bdesc=GEAR+HOUSING<br /><br /><br />Impeller part number 47-803630T from any Merc dealer.<br /><br />Compression tester from any tool/auto parts store, Northern Tool, Sears.com, etc.
