85HP force bogs down konks out
ejm845
was given 89 bayliner with very low hrs on it had entire ignition done to get it running marina that did work told me it ran good but they used their fuel tank and to drain my gas but I already but 15 gal fresh gas in with 5 gal 2yr old gas so i took it out had to start it with starting fluid run great at first then it would bog down at top end and slowly shut down sequence would repete every time i tryed only a little worse each time any sugestions would help
roscoe
Re: 85HP force bogs down konks out
Do not use starting fluid on a 2 cycle engine.<br />1- it removes what little oil is in the engine.<br />2- It doesn't supply any oil, so you are running the engine without oil, and it will soon die.<br /><br />If you need to squirt something in the carbs to get it going, use pre-mixxed fuel in a squirt bottle.<br /><br />But more importantly, find out what is wrong and fix it.<br /><br />Start with the basics, check for spark, fuel, and compression.
Realgun
Please tell me you mixed your Oil with the Fuel.<br /><br />Casue if you did not your running your motor without oil and doing serious damage.<br /><br />>>>>>>>>>WELCOME TO iBOATS!!!<<<<<<<<<<<<<<<
Realgun
BTW sorry.<br /><br />The correct mix is 1 part oil TCW-3 to 50 parts gas.<br />6oz of oil to 1 gallon of gas or 1Qt oil to 6 gallons gas. Use regular no premium needed here.<br />Next thing I would do is get some TCW-3 OIL and spray it into the cylinders. Remove the spark plugs first. Tun the motor over with the starter for 10 seconds BUT have the Kill switch off so It will not start.<br /><br />Spray oil again and turn it for no more than ten seconds.<br /><br />Put plugs in and pump the fuel bulbn hard. You did mix oil and gas right? Then start it ewither on a hose or at the lake. Never start the motor without water to the lower unit or you will kill the water pump known as the impeller.<br /><br />Do a search and you will find the maintence items here some where I am getting tired of typing them out ROSCOE!
ejm845
the gas&oil are mixed correctly do you think the 5gal of 2yr old gas could be fouling the whole tank or maybe there is water in tank if so why only problem at start up and high end
