Bait O' Eggs
- Joined
- Apr 29, 2002
- 3
I currently own a 10 Hp honda long shaft, I am not sure of the year but the serial number is B100L-1400134 (older blue and white model probably mid 80's) I have ran it for 3 or 4 years with no problems. I recently developed a problem with water in the oil. In the process of trying to resolve the problem I have broke off 3 bolts in the head where you access the thermostat. I have destroyed my current head trying to remove the broken bolts.
<br /><br />I have found a used head I can purchase for $75 but am not sure I have found the problem where the water leaks into the oil is. I did find a bad gasket on the oil drain plug which may have been the problem. When I pulled the head I did not find any clues that show the water was leaking at that location. <br /><br />I have also found a 10 hp short shaft of what appears to be the same vintage, maybe a little newer serial number B100S-1702682. This motor has no lower end as it went bad and it is taken apart and sitting in a box for a few years. <br /><br />I want to know if it is possible to put my lower end on my long shaft on this short shaft motor and make the short shaft a long shaft. Do the bolts match up on both models????<br /><br />I hate to buy a new head for my current motor and still have the oil/water leak problem on my current motor not resolved. <br /><br />I need to know if this is an option before I buy the short shaft with the bad lower end.<br /><br />Maybe I can steal the head off the short shaft and make my long shaft work (assuming I can find oil/water leak) and have some spare parts like carb, hood, skeg etc.......<br /><br />Thanks for the help.
