Honda 75 hp
enn
To make a long story a little shorter:<br /><br />I just rebuild a Honda 75 hp modelyear 1996 - new pistons etc. but i need a new/used cylinderhead compl.<br /><br />I have tried everywhere to find a used one - but havent been able to locate any.<br /><br />Can any of your fellow boaters in USA help me?<br />Do you know of anyone who haver a used Cylinder head for sale? could you ask your local dealer?<br /><br />The engine is like new - but i bourght it cheap from the original owner - the engine had been drowned and had run with water in the oil - one valve stuck and the valvehead was knocked off by the piston - the engine ran with this loose valve inside cyl 4 for app 3 hours - the cylinderhead was badly damaged and the cylinder needed oversize pistons and the crankshaft needed grind/oversize bearings .<br /><br /> :rolleyes:
D
DJ
Guest
Re: Honda 75 hp
enn,<br /><br />I'm not so sure that this head is not the same as a Civic automobile.<br /><br />If you have it in hand, take it to a machine shop that carries these rebuilt heads (Honda cars) and make a comparison.
enn
Re: Honda 75 hp
Well - i have often heard that the 75/90 hp should be made from Civic engine parts - but it is not true.<br /><br />I am a marine engineer and have had several Civic cars and been rebuilding a few.<br /><br />What i can tell for shure about the 75/90 hp models are:<br /><br />The first series in 1996 (up to serial nr app 2500) had a civic crankshaft and conrods from a civic - all other parts where not similar to the Civic engines.<br /><br />The block and cyl.head is for shure not at all familiar with the civic engine.<br /><br />I have checked it all out and have original workshop/parts manuals for both the OB and the Civic car engine.<br /><br />The 75 hp i have been rebuilding are among the first 2500 made - so i could get OS bearings for it (this is not possible to get as original Honda Marine parts) - i checked to see if the Civic pistons would fit - but they are quite different from the Car pistons - and I had to buy original Honda Marine Pistons in OS.<br />The crankshaft are surface hardened - and to grind requires that you get it re hardned - all this have been done by a local machine shop that are used to work on Honda engines.<br /><br />The cyl head is damaged beyond repair - and i am desperatly trying to find a used one.<br /> :confused:
D
DJ
Guest
Re: Honda 75 hp
Well, it was a guess.<br /><br />I think you're going to have trouble finding a used one. There are not that many out there to begin with, and very few have failed.
enn
Re: Honda 75 hp
Well it is worth a try - a new cost app 1500 USD over here - and you have to ad springs valves etc. so around 3000 USD is probably the price for a complete head.<br /><br />I can add that the motor was originaly owned by a man on Greenland - he used it for transport betwean the small cities near Søndre Strømfjord- it is a wery remote place - so he had to make it back with the engine (and did) but it took the life out of the engine.<br />I am quite impressed that the engine ran 3 hours on that water/oil emulsion - and that it came back on 3 cylinders.
enn
Re: Honda 75 hp
No it is not an ACCORD engine - have tried that also (BTW there is no 1590 ccm Accord engine)
Frank Martin
Re: Honda 75 hp
can probably get you a complete motor cheaper than the head they have some honda repo motors at the chicago warehouse no warenty from dealers tha went out of buisness these where on boats in the water fresh water call me 708-862-2407 Frank
