tenacrewoods
Thread starter- Joined
- Jun 13, 2002
- 26
I own a 14'x70" flat bottom AlumaCraft with 1995 40hp Tohatsu #M40C two cylinder,prop is 10.2x13.9, gear reduction ratio is 13:25,rpm range is 5200 to 5800,weight is 135lbs and load I'm pushing 1005 lbs total,cavatation plate is 1/2" lower then bottom of boat. Not sure of rpm I'm running at WOT,but getting 30mph now.Can I use a 11x 15 prop recomended for M40D three cylinder or what do you guys suggest.Would like to get 35mph out of her.<br /> Thank you!<br /> Mike E
