Scott Duff
Thread starter- Joined
- Aug 19, 2002
- 3
Honda BF25A - A mix of fluids appears to be leaking into the crankcase oil. Mechanic indicated water and gear oil in crankcase oil. Twice after 50 hrs heavy use at all speeds/hot weather the oil was very dark, thin, with at least 8 oz. added volume. When checking oil level, it overflowed in quantity at the dipstick. Another mechanic attributed this to "blow-by" past the rings. After running 10hrs on fresh oil at lower speeds there is a tan appearance to the oil and some water at the drain bolt. Operation is very smooth with super easy starts and no skips or hesitations. However, there is a small amount of oil observed on the water's surface for a few minutes after starting. Motor purchased last summer used (I'm 2nd owner). Motor has many hours of trolling in 5yrs.
