Honda 8 HP 4 stroke oil gets gassoline??
hardhat
Hello I have a honda 4 stroke 8 HP out boerd engine, we had a mecanic service it a few mont ago but ever since the carburator flods and is hard to strart we have to keep bleading the gas overflow of the carburator and dry the spark plugs several times before it starts but the problem now is that it starts just fine but the gasoline gets in to the oil and it overflows it we have check just about everything and canot fing the problem<br /><br />any one has any ides of watt it may be or watt ne need to check I am under the Impression the carburator may be dirty but it loks just clean<br /><br />thank you :confused:
Navigator
Re: Honda 8 HP 4 stroke oil gets gassoline??
Hardhat,<br /><br />If it is flooding, does the primer buld ever get hard when you first prime the carbs, or does squeezing the primer buld flood the carbs?<br /><br />If sounds like maybe the needle valve on the carburator float is stuck in the "open" position. Pull off the bowl on the carb and make sure the float moves freely. The needle valve should be able to move freely too. Also, check the condition of the needle valve. It should have a very smooth taper. If not, the valve may be damaged and needs to be replaced. (If its not smooth, it wont seat correctly and will let fuel get past).<br /><br />Nav :cool:
Skinnywater
At the same time check that the float isn't saturated with gasoline.
Yepblaze
A hole in the fuel pump diaphram might saturate the oil.<br /><br />As far as the carb flooding, I've seen a Honda carb leak around a pressed in seat assembly, and needing complete replacement
hardhat
Thank you all for your coments and sugestions The carburator was dirty and the floater was getting stuck on the open possition<br /><br />also the dyaphragm was dirty and in cosecuence and thegassoline intake hoses were taking air<br /><br />so much for paying a mechanic to do this<br /><br />thank you all
