Salmon Tub
Thread starter- Joined
- Aug 13, 2003
- 36
I am a new member here, so I would first like to say hello to everyone. I am a big fan of Nissan/Tohatsu, and have 5 of them myself. A 3.5, a 5, an 18, a 40 and a 90. The 90 hp Nissan is a late model 2-stroke that is on a 17' BW Montauk. In any case, I am having a difficult time adjusting my motor simply because I am not sure how it is supposed to run when adjusted correctly, I mean how smooth is smooth? The idle in water, out of gear is fine (900 rpm), the idle out of water on muffs is fine (1000-1100 rpm), but the problems start when in gear. I do a lot of trolling, and the previous motor that I had on this boat was a 40 hp Tohatsu, which also idled poor in gear (my opinion) but I trolled that boat at 1100 rpm in gear, so the trottle was always advanced a bit. The things that concern me with my 90 are the following: When out of gear but idleing in the water (back pressure), it is at 900 rpm, then the rpm's will drop to about 600 when placed in gear. The book (Clymer) and sticker on the engine call for 900 out of gear, 750 in gear. I can not seem to shrink that difference down from 300 to 150. It is the same with both a 15" and 17" pitch prop. I have set the timing per both book and sticker at 5 ATDC, original was set at 3 ATDC. I have checked all linkages, and the oil valve (not check valve), and they are all within spec. as per book. I have also adjusted pilot screws, and adjusted, and adjusted, and... to the point where I don't know if I will ever get her to run well. The page out of the Nissan shop manual (not Clymer) calls for 1.5 turns out +/- .25 turns and +1/8 turn for cold start. Pilot/mixture screws are not always a science, and that cut and dry. I have noticed that when in the water, in gear, if the pilots are way out of sync. but within spec., the needle on the RPM guage will start to jump from 300 to 600 rpm, there is little audible difference at that point in the sound of the engine. So, this I take as a tell tale when the pilots are seriously out of sync. The reason for all of these adjustments, is that outside of the obvious (needle jumping) the engine seems to vibrate a bit too much, more than my 18 hp Tohatsu at idle, which makes little sense to me. The vibration is not the shallow fast vibration, but a slow, un-even deep kick, that is just plain annoying. The most important problem is that Cyl. #3 fouls the plug fast (25 hours/20% trolling). Last year I had to come in on 2 cylinders due to a failed plug. That incident stays in the back of my mind every time I troll now, and I find myself a little hesitent to troll for longer than a half an hour. The last time I adjusted the pilot screws, (richened all up about 1/4 turn) I set them at about 2.125 open, 1.875 open, and 1.625 open, from top to bottom. This gave the highest RPM's was fine on the water, but when flushing at the end of the day, it would idle, then drop rpm's as if to die, then come slowly back up, then drop again. In order to stop this, I had to lean out the top, and richen up the bottom to 2, 1.875, 1.75, and this helped, but upon checking the plugs the next day, 1 and 2 were fine, but #3 was even darker than the previously. So, to prevent fouling, it seems I need have #3 leaner than 1.625 open, but that causes that roll when flushing as well as not running at top RPM's. One bit of reassurance was when I saw a Mercury 90 2-stroke running at the flushing station, it too seemed to have that kicking vibration, offcourse, it may be out of adjustment as well. I know this is a long post with a lot of information, but I would appreciate any help. How smooth is smooth on a 90 hp Nissan at idle?
