stoeptegel
Thread starter- Joined
- Jun 30, 2004
- 10
Hello,<br /><br />I have an old (unknown build date) B100 which acts up a bit. It starts first pull. It runs great most of the time, but sometimes when @ higher revs, it stalls. Sometimes it even dies when this happens. Going from idle speed to half or WOT it hesitates. This all made me wonder if the carb was clean, so took it apart, cleaned it. Does not fix the problem..<br /><br />Grabbed a Xenon lamp, tested timing. Timing ok, when it stalls it does still spark. Hmm.<br /><br />Ok now the questions:<br /><br />The B100 has no airfilter. Only a mesh wire in a plastic in front of the choke valve. Is this normal (it would seem to me not to be ideal for the carburetor).<br /><br />Any ideas on the stall going from idle to higher revs? When engine is cold this problem is less evident.<br /><br />Any suggestions on what to check/where to look are highly appreciated, and yes I am trying to get a workshop-manual (so far, local Honda dealers dont want to sell them, they want to fix the engine)<br /><br />Thanks,<br /><br /><br />David (currently using a Mercury 2 stoke 8HP ughe ughe)
