2002 Honda 90 - This moter is still new, two summer seasons in clean/fresh water only. It has performed flawlessly and only has 105 hours of use. However, I have two problems/concerns (note, both since the moter was new...) and I wonder if I should haul the boat back make issues of these with the dealer: <br /><br />1) Smoke Upon Startup - If after shutting the motor off, I leave the moter fully trimmed down for any period of time more than a few minutes, it smokes (sometimes lots) upon re-starting the motor. After starting the moter, the smoke only persists for about 15 seconds then it clears up. I described this to the dealer and he said he had never heard of a Honda smoking? Note, when fully trimmed down the moter does angle back past 90 degrees away from the boat towards the water a bit but this trim angle doesn't look at all unsual. I suspect crankcase oil must be leaking into the cylindars and burning off when I start the moter? Is this normal? Is it cause for concern? Valve problem?<br /><br />2) Noise - Particularly when quickly decelerating, there is a strange whining noise. It is less noticable at any stead speed. I have had several mechanically savy folks, listen and it is definitely in the motor (or lower unit) and is not related to a water/hull sort of noise.<br /><br />Any thoughts or suggestions we be great.<br /><br />Thanks!
