I built a custom Bateau OB17. It's a c console bay boat with a modified vee and has a 70hp yamaha 2 stroke. When I get up to around 4500 rpm - wot she porpoises a lot. The recommended wot range is 5-6000 for the motor, with a 13-1/4" x 17" cupped aluminum prop I can only hit 5000 rpm. The motor has the a/v plate mounted even with the bottom, with 2 holes to move up. I've been in touch with the designer and he say's to move my weights forward but I already have a 12 gal gas tank under the casting deck and an anchor, chain and rode and some other equip. stored forward. She runs better with one person on the console seat. The problem is that I can't trim the motor up much at all and she starts to porpoise. I know trimming up would increase my rpms signifigantly but I really can't without the porpoising. <br /><br />I checked my hull and I do have about a 1/16-1/8 hook on either side of the keel over the a run of 4 feet from transom foreward. The designers say that rocker will cause the problem and not a hook. I've also read some conflicting posts here debating hook and rocker causing porpoising. <br /><br />A few guys said that I had the right prop and should turn the correct rpms when I get her not to porpoise and trim out. Should I go with a 15 pitch prop? Raise the motor? I will try to fix the hook with some epoxy and fillers but that's going to wait till winter.<br /><br />Sorry for the long post, any help is greatly appreciated!
