Hi: I am a new member and this is my first thread.<br /> I have owned my 89 15B2 Tohatsu for two years now, so decided to replace the impeller. Following the service manual, I removed the four nuts and washers that hold the lower gearcase on the drive shaft housing, then removed the upper spring pin from the shift rod joint. The manual states that the lower gear case should drop off. But it would not come apart. I tried to separate it by pounding on the lower unit with the butt end of a two foot long piece of 2"X6" wood, but it still would not come apart. So, after removing the engine cover, I turned the OB upside down and sprayed WD40 onto the gear case bolts and tapped on them with a brass ballet. I also used a razor blade and cut thru the paint where the unit is supposed to come apart, then sprayed that area also. I then removed the lower swivel mount bracket which then allowed me to see into the drive shaft housing where I could see the drive shaft. Thru that hole I sprayed more WD40 so it would run down the drive shaft and onto the drive shaft splines. I let the parts soak in WD40 for two days, then started pound on the lower unit again. It still would not come apart.<br />I'm at my witts end. I still don't know where the problem is. At the drive shaft splines, or the area where to two sections mate together. If anyone has any suggestions, I would appreciate any help given.<br />Thanks, Frank
