When I initially start the motor cold Is there a starting sequence for it that I am missing. Right now I pull the choke out for about 3 pulls and then no choke but it takes about 20-25 pulls this seems alot for the starting of this motor
I have the same problem. I watched a mechanic start mine. He pulled out the choke, put it in gear, throttled it up, and pulled the cord 4-6 times. Then he returned everything to the start position. It starts that way, even in cold weather, in 4-6 pulls.
Hard starting can sometimes be a valve clearance problem.........maybe check them.
Alex
